phát điên với mấy cái lỗi trên VOS 3.0, tìm đc bài viết cài stock fw của Meizu 16Xs. Cho hỏi có bác nào chuột bạch thử chưa ạ, máy e còn BH gần năm nữa nên ko dám thử.
How to Install Stock Firmware on Meizu 16Xs
1 Download Stock Firmware/Flash File For Meizu 16Xs:
1.1 Note-
1.2 Firmware Information:
1.3 Downloads:
1.4 How to Install Stock Firmware on Meizu 16Xs:
Official Stock Firmware Flash File now available for the Meizu 16Xs & You can Download it From Below. Official Stock Firmware for Meizu 16Xs Will help You to Restore Your bricked device by using the QPST tools.
Meizu 16Xs Run on android 9.0 & it is Powered by QCOM SD 675 Processor. it is a Dual SIM (GSM) Smartphone Support Nano-SIM Card’s, Connectivity options include Wi-Fi, GPS, Bluetooth, USB OTG, FM, 3G & 4G.
The Device come with 6GB of RAM and 64/128GB of Storage that can be expandable via SD card. in camera department it come with 48+8+5MP Rear camera With 20MP Front Shooter.
Note-
DeviceName:Meizu 16Xs
Type: Full ROM
Size: up to 2GB
SoC: QCOM SD 675
Os: Android 9.0
Password: Null
Root access: Not
Gapps: Included
Firmware Version: M1926_Flyme7.3.1.0G
Firmware: Meizu 16Xs: Download
Flash Tools:
usb Driver: QD Loader Driver: Here
1.1 Note-
1.3 Downloads:
Note-
- Please Do carefully, we are not Responsible for any damage to Your device.
- Flashing the ROM Will Erase all Your Personal Data Including Storage. So we advice You to First Make a Complete backup of Your Phone.
- Ensure that Your Device at-least 50% Charge During Flashing Process to Prevent accidental Shut Down.
Type: Full ROM
Size: up to 2GB
SoC: QCOM SD 675
Os: Android 9.0
Password: Null
Root access: Not
Gapps: Included
Flash Tools:
- Download & Extract QFIL tools
- Download & Extract Firmware Package
- Install QD Loader usb Driver on PC
- Connect Phone to PC & Reboot to EDL use code Via adb: adb Reboot edl
- You Can usb Driver Like below Image in Device Manager
- Run QFIL and Load Programmer and XML Files From ROM Folder
- Click Download
- Wait until Success. Your Phone Rebooted
